It’s always fun to have a new computer.
I’ve got a Workbook, which takes a sheet, and then saves the sheet as a file of its own and after that I attaches the workbook to Lotus Notes. The final operation is executed using a simple “.sendmail” command. Currently I have been receiving a regular IBM Lotus Notes error message.
The message says that, “File Automation-embedding.nsf does not exist. ” My I. T. associate says that, the trouble is with the code but I don’t really agree.
Could you please help me with this?
IBM Lotus Notes Automation Error
Your I.T. associate says that, the trouble is with the code and it is absolutely right!You might have done some action that caused your application source code to be changed. I think it only happens to you only one time just after you reboot your device and once you click ok it did not annoyed you.
But if you shut down and start your device same thing will happen again. But you may come out from this problem by fixing locally. Method: running fix up if there are two users,updall -R,compact -C,try to delete cache.ndk.
You also can resolved this problem by bookmarks.nsf ,
Ok good bye.
