IBM Lotus Notes – “File Automation -Embedding.nsf does not exist”
Hi all
I use Lotus Notes like streamed applications as well as I have used a third party app and it sends e-mails using Lotus Notes via the object Notes.NotesSession.
Also,I have connected my third party app to Lotus Notes. However it cannot send mails, I find the error message in Lotus
Notes "File Automation -Embedding.nsf does not exist"
Moreover,I have a VBS Script, and it attempts to send an e-mail in the similar way via the object Notes.NotesSession.
When I try to run this script as of an app connected to Lotus Notes it is unsuccessful and if I try to run the script as of in the Lotus Notes packaged it runs.
COM does not look like to work fine between linked profiles.
What should I do now?
Please help.
Thanks
