While I was working in IBM Notes this error appeared suddenly and I had to close the program and open it again. It started to be an error very annoying and I would like to get rid of it. Can anyone help me please to fix this one ? What is causing this error ?
Thanks !
Notes 9
An error has occurred in an IBM Notes application.
Data about the error is being collected for you company’s help desk for use in error analysis.
The IBM Notes application will close when data collection is complete. Please wait.
IBM Notes Error Notification about Notes 9
First, check if your computer meets the necessary requirements for Lotus Notes 9. For Windows, the supported operating systems are Windows XP Professional Service Pack 3 x86 only, Windows 7 [Enterprise or Professional], and Windows 8 [Enterprise or Professional] both x86 and x64. If your operating system is supported but you still get the error, try reinstalling it.
For Mac, it supports Mac OS X 10.7 Lion and 10.8 Mountain Lion. For Linux, it supports Red Hat Enterprise Linux Client 6 x86 and x64, Ubuntu 10.04 LTS x86, and Ubuntu 12.04 LTS x86. Uninstall Lotus Notes then click Start, All Programs, Accessories, System Tools, and then select Disk Cleanup. Select drive C and then click OK. Check “Setup log” and “Temporary files”, click OK, and then click Delete Files.
Restart your computer and then install Lotus Notes back. Try it again and see if it works. If the problem continues, try starting Lotus Notes as administrator. Right-click on Lotus Notes shortcut then select Properties. Select Compatibility tab then check “Run this program as an administrator” under “Privilege level” section and then click OK. Try it again. If nothing seems to work, try updating your operating system to the latest Service Pack. For Microsoft Windows 7, the latest Service Pack is Service Pack 1.
