Hello to all.
I am trying to add an event on the iCalendar of my iPhone but I found out that there is no invitee option.
I checked on the iPhone of my brother and found the option there.
Why I cannot see it with my iPhone?
What possible solution can you give?
ICalendar invitee option is missing
not only you suffering this problem, many people also.
There are some causes of missing invitee option;
If you didn't setup Google calendar properly.
Immobilizing location based time zone setting can be a make this problem.
Here some solution. you can try to solve this problem.
You can try to adding an event and try to invitee contacts to it. you can see the invitee option.
You can setup Google to be synced via exchange. after that you can see this option.
You can use Mical. It shows all imported calendar and its corresponding color. Swipe your ways throw and views. it's fast and easy.
This problem is encountered commonly with iPHONE nowadays. Just follow the given steps and you may have your solution.
1. You must have Mobileme.
2. Download the recent updates for iPHONE and system (Computer or laptop).
3. The updates will take a few minutes of your time and you will have the invitee option on your iPHONE.
I hope this answers your question.
