Is Icc Cat6 Patch Panel The Best Patch Panel?
Asked By 35 points N/A Posted on -
I am looking for a 48 port patch panel and I have been suggested to buy the icc cat6 patch panel by a few people. I need it for college purpose where many students will be using the panel for gaming, data transfer etc. Will icc cat6 patch panel meet all the requirements?
Answered By 0 points N/A #200425
I am personally using the icc cat6 patch panel for the same purpose as yours. College students need one of these necessarily. I have not faced any problem yet. This is a rack mount panel with two rack mount spaces. This works very well with data networks that require high speed and bandwidth. It is compatible with all lower rated category components. It is also UL listed. The panel is designed such that it fits in all standard 19” racks. Mounting screws come along with the panel and it is very easy to fix it. This is a very good choice for your purpose. For more details, visit
https://icc.com/product-category/patch-panel-and-cross-connect/110-type-patch-panels/110-type-patch-panels-cat6/
