Hello…
We have been often using Citrix MFU. When consumers seek to launch ICFB (Cadency) tool, these people have the at a lower place mistake:
Using Cadence version ic5141_isr141
*ERROR* Failed to find either 24-bit True Color or 8-bit Pseudo Color Visual.
*WARNING* Failed to find either 24-bit True Color or 8-pbit Pseudo Color Visual.
OS is Solaris 10 9/10 and using CDE.
Please give me tips on this.
ICFB tool error using Citrix MFU
This is pretty common error that most people face when they use the 24bit or 8bit colors.
Actually the supported colors by it are the 32bit and 64bit if it is available.
You must consult the documentation of the software to see which other color schemes are compatible with it.
You might also have to reconfigure your application because there is a chance that the user that will run your application don't have the require components that needed for the application to display properly.
You have to look for all these possibilities.
About the warning, ignore it as it is only due to the error that you are facing. Once you will solve the error, it will be removed.
