I've been trying to enabled iCloud Syncing with Downcast but always end with the error below.
How can I enable iCloud syncing?
Error Initializing Cloud Sync
All iCloud syncing has been disabled due to an initialization error. Check the Help section for possible solutions.
ICloud Syncing has been disabled
Hi
I have seen your site and there is no drop down menu and the menu styles seems that the menu gadget is a drop down style you need to check in backend in the menu module there is an option of drop down you need to select that option and select it as a YES. And one more thing you need to create the subpages same as the parent pages and then put those sub-pages under parent pages.
I have not seen any page under the main menu. You need to clarify have you created the pages and have you enabled those subpages. These are the little mistakes due to which some things not working. Hope you understand. If it is still not working then reply me. And check out your site offline message.
I have sent you one message on your site. Offline message checks that message.
Hi Juan,
This error is because Downcast encountered an error when enabling iCloud syncing.
The solution to it is:
1) Ensure that ‘Documents And Data’ is enabled in your iOS iCloud settings
2) If you continue to receive this message, follow the steps below:
a) Disable ‘Documents and Data’ on the iOS iCloud settings
b) Open Downcast and enable iCloud syncing
c) Re-Enable ‘Documents And Data’ in iOS iCloud settings
3) Restart the application, the error will be resolved
