noah powell
Posted on - 11/30/2011
I have downloaded and installed iCloud application on my iMac. On dragging and dropping files into the iCloud will let me view the online files even from iPad. My problem is I could not locate the version of iCloud that is compatible with my iPad. Hence, I am unable to upload the files in my iPad. Is there a version of iCloud that can be installed in iPad so that these files can be transferred easily?
oscar57
ICloud Version for Transferring Files on iPad
There are 2 ways to solve your dilemma.
1. Please update to the latest version of IOS 5 and follow these instructions;
Please tap on the Settings app
Tap on “iCloud”
And choose “Sign in with an Apple ID”
Please enter your existing Apple ID (iTunes account), and or an older MobileMe account
Choose “Use iCloud” at the setup screen
Tap “ON” switch for the types of data and services to sync with iCloud:
After you've configured all of this go to ICloud.com to use your web apps.
2. You can use Dropbox alternatively for syncing your files. Follow this link for instructions
https://www.dropbox.com/help/mobile
