Icon Not Displaying Properly on Windows 7
I am using a new HP computer that is running on Windows 7.  I am however having difficulty setting it to display the Google logo – red, white, green.  The IE world icon does not encounter any problems at all and is being displayed properly.  In Win XP I was able to change the icons easily as there were several options to choose from.  I would also like to change the files on display only as an open envelope on the desktop.  Please help. Your ideas will be greatly appreciated.
Answered By 0 points N/A #101852
Is that an application that you trying to open the Google logo in or are you trying to customize the appearance of the Google logo on your computer? If it is application, then I will be glad if you mention which application it is so that I can be able to see if I have an idea what is going on with it.
But if you are changing or customizing the look for the Google logo on your computer, then there should not be much of a difference when you are doing it in windows 7. The process should be same as you had done in windows XP, unless you have changed the browser that you are using.
-Richard Gabriel
