Iconia tablet pc-android system not working
My new aconia tablet pc touch screen is not working. I do not know what is causing this problem.
I need to know if that is a software problem or a hardware problem.
Please someone help me identify this problem, and I will be really glad.
John Parker
Answered By 15 points N/A #116642
Well John Parker,
Since when did you encounter the problem? Did you drop it or something like that happened before the fault occurred? Overall, it seems to be a hardware issue. The problem could most probably be in the digitizer of your screen. Digitizer is a small sheet on the back of the LCD and if there is some issue with the digitizer or it gets misalignment slightly, then the screen gets blank.
You need to take your system to a hardware expert who will open it up and see the actual fault in the systems. If it really is the digitizer, then it is good as it is not very costly. However, if the issue is in the motherboard, then it will be a lot of money to spend for you. In that case, you can analyze if you want to get it repaired or sell it as it is for hardware components.
I hope though that it is only the digitizer and your problem will be solved.
