Ideal network with good authentication scheme
What is the ideal network that uses a good authentication scheme which involves both PC Users & MAC users? What is your idea about it? Thanks.
Hello Riley Hall,
Your question is a bit generic, because I am not getting whether you want assistance on installing a small network or large network. You could have at least stated the type of organization that you are in.
In case you need to use many computers on the network, then I will recommend that you use the star topology that will allow you to work with many servers so that when one goes down the network remains operational. I am hoping you already the components you will need so as to set up the network.
Hope this helps.
__
Regards
Lee Hung
