I am having problem with my Internet download manager. When I try to download any file from the browser an error message occurs saying “Cannot transfer file download to Internet Download Manager. Error 0x80004002”. I could not fix this problem by downloading IDM again. Please provide any suggestion to resolve this issue. Thanks.
IDM CC extension
IDM CC extension shows error
Hey Mr. Ponder,
This is a very common error facing Windows users and is the result of problems while installing Windows Update. There might be compatibility issues also with the IDM.There are several more reasons to Error 0x80004002 like malware infections , registry errors ,etc.
To sort out this issue you can directly by downloading the following software. It has a known track record of solving out this error.
http://www.0x80004002.org/Error-0x80004002-Repair-Tool.htm
points
Such problem can be solved by installing IDM in correct order. IDM CC is unable to locate the installation of IDM’s core and so unable to pass the file to the program. Installing the program completely new will solve this issue.
1. Download latest IDM.
2. Uninstall the older one from Start menu >> Control Panel >> Programs >> Programs and Features. Make sure to choose “Complete” uninstallation process.
3. Restart your PC.
4. Install the latest IDM.
5. Restart your browser.
Now, downloading should go fine.
Enjoy!
Its look like you do not use the valid path to install you IDM program and that's the reason that you are getting some problem in your installation. Anyways, pay a visit this Techyv post because this post is also addressed your problem.
Internet Download Manager installation error
