IDSERR_LOADLIBRARY Error in Norton Antivirus
I am attempting to install Norton antivirus which I got from a gaming website. When installing it on my Windows XP system, the installation stops in an IDSinst.exe alert box with error: IDSERR_LOADLIBRARY. How do I fix this kind of error? Please help me.
Answered By 0 points N/A #123190
Jerry Hi
The Anti Virus version you do not refer. Cause your version must relate with Windows xp. There are lot of gaming sites are publishing various program but they are some fake.
You have to check the version and register system. May it was the trial version for Mobile or computer system but from 2 years ago.
There the message on your screen during installing already showed that. so the exe file would not able to recognize it.
Register and original version you have to install to your PC. collect the Anti Virus from remarkable website or buy from shop. This is going your solution for your system saving.
