IE 10 for Windows 7
Is there any support of IE 10 for windows 7.
If it is available how do I install that in my Windows 7 64 bit OS.
And where Can I download it.
At first, please check your windows operating system whether it is 64-bit or not
To do this, right click on the computer icon placed in the desktop and go for properties.
There you can find the information about your operating system.
If you have windows 7 64 – bit operating system, then please go to the link:
This is a link of flash player according to your operating system.
All I have to say that you need a compatible flash player to operate Internet Explorer as a support.
Remember that, While installing that flash player, you have downloaded the flash player for 64-bit
Microsoft Windows 7 comes pre-installed with Windows Internet Explorer 8 by default while Windows Internet Explorer 10 ships with Microsoft Windows 8 by default. Though Windows Internet Explorer 10 is not included in Windows 7, you can still install it and upgrade your existing Windows Internet Explorer 8 to version 10. Go to Windows Internet Explorer 10 for Windows 7 then download and install it.
If you have 64-bit Windows 7, go to Windows Internet Explorer 10 64-bit for Windows 7. Microsoft has already removed all the download links for Windows Internet Explorer 10 and probably including earlier versions. Since this download is from a different website, though I trust FileHippo, better check your download with one of these SHA-512 hashes:
Notifications
