Bryan Misha
200 points
Posted on - 06/11/2011
I am having issues in my computer. I am using a Windows Vista machine.
My problem is, my Internet Explorer does not work with AOL. Even if I am not logged in at AOL, and even if I will exit AOL from the system tray. I am thinking there’s a conflict between the two.
However, I do not want to give up any of those. I tried using other browser, but I still liked Internet Explorer more than anything else. It works faster in all my favorite web pages that I am visiting unlike Mozilla and Netscape.
Are there any more options to make them both work at the same time?
Compatibility issue between IE and AOL
Just for additional information, AOL works with Internet Explorer 9. AOL works even with other browsers too. Since you are having issues when using Internet Explorer, I suggest to please turn off the firewall and try to do a Powercycle on your computer. Powercycle is just like a rebooting your computer. Please follow the steps below:
Please turn off your computer.
Please turn off your router (if any).
Please turn off your modem.
After 60 seconds, please turn on the modem then the router (if any) then your computer.
Please make sure that you turn off the equipment in the right sequence.
