randysprang
1230 points
Posted on - 06/16/2011
Hi fellows,
My system issue is about Internet Explorer. I have been using this browser for office work doing data entry to a web based application. While working, the annoying error message will pop up that says internet explorer experience some problem and it will close. As I read the error message, it did not state any reason on the error or suggest any remedy.
Internet Explorer
Internet Explorer has encountered a problem and needs to close. We are sorry to inconvenience. If you were in the middle of something, the information you were working on Might be lost.
As I isolate the problem, I excluded the web based application since other data entry worker is running smoothly. So I now conclude that its my browser having problem. I cannot use Firefox ,since our web application is best viewed with internet explorer. I hope, I can get some help on my problem.
‘Internet Explorer encountered a problem’ Error
The most common reason of this problem is old yahoo version toolbar,so i think there is a toolbar of yahoo old or corrupted version in your computer. Now resolve this problem quickly remove or uninstalled the toolbar and restart your browser.
Now you can install new toolbar of latest yahoo version.
Microsoft Internet Explorer can easily get errors when loading just a simple page with some JavaScript on it. I don’t know if others will agree with me but this is a very unstable web browser unlike Mozilla Firefox, Opera browser, or Google Chrome. But if this is your current state where you really can not use other browser besides Microsoft Internet Explorer, you can try upgrading it to the latest release.
You can download Microsoft Internet Explorer 9.0.8112.16421 which is already installed on Windows 7 32-bit edition.
You may also try checking your computer for any possible errors. Use a disk utility application when checking the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit or Norton Utilities. Any errors in the hard drive’s file system can cause different application conflicts and will not properly work in some instances.
