Iemecu Cab Error While Installing New Operating System
I tried to update my Windows 7 version since my laptop is six years old. During installation, I came across few errors among which “Iemenu.cab not found.” was one. Please provide me the solution
Answered By 150 points N/A #313028
So here are few solutions which may help you-
  • This error can occur due to the presence of any malware in the system. Scan, and fix it.
  • You can make use of
WinThurster Now will resolve all your problems related to the Iemenucab issue
  • Install all available windows updates which can help you to find your Iemenucab
  • You can make use of windows system file checker which will tell you where the exact problem is present.
  • You must. Scan your PC for cab-related registry errors.
Answered By 590495 points N/A #313860
That error is probably from the installer you used to update your operating system. If you want to update Windows 7, try installing the latest Service Pack. Download Windows 7 Service Pack 1. This is the latest and only Service Pack update for Microsoft Windows 7. This Service Pack update helps your computer keep supported and up-to-date.
It allows you to receive ongoing updates to the Windows 7 platform. It allows you to easily deploy cumulative updates at a single instance. After updating to Windows 7 Service Pack 1, download Platform Update for Windows 7. With this platform update, it enables enhanced features and performance on Windows 7 Service Pack 1 and Windows Server 2008 R2 Service Pack 1. It includes updates to the following Windows components:
  • Direct2D
  • DirectWrite
  • Direct3D
  • Windows Imaging Component (WIC)
  • Windows Advanced Rasterization Platform (WARP)
  • Windows Animation Manager (WAM)
  • XPS Document API
  • H.264 Video Decoder
  • JPEG XR Codec
