Sampras
410 points
Posted on - 06/08/2011
First of all I would like to thank the admin to run such a useful site and the experts are doing a great work too. Here is my problem:
iexplore.exe – Application Error
The instruction at "0x01cc3812" referenced memory at "0x01dbdf8c". The memory could not be "read".
Click on OK to terminate the program
I am running Internet Explorer 8 on my laptop which is running on Windows 7. My Internet Explorer showing an application error in the middle of browsing and on clicking OK button it crashes immediately. I remove some of the add-ons but its not working and I am out of luck. It is irritating me too much and need a quick solution. Please help me to troubleshoot this irritating problem.
Iexplore.exe Application Error in Internet Explore 8
Hello Sampras,
Here's the solutions for you, you can do any of the following given. Hope to hear something from you. Feel free to ask more questions here at Techyv.com, it will surely do help you. Having a problem? Or some research for your school lessons? Just ask help here at Techyv.com, we love to help you.
In your first move try first to uninstall the Internet Explorer then re-install it again. By doing it, follow these steps:
Step 1 – Press the windows key -> select Control panel.
Step 2 – On the control panel -> select Add or Remove programs category.
Step 3 – Select the Internet Explorer then click the change/remove button.
Step 4 – After removing the Internet Explorer.
Step 5 – Restart your computer now. When computer finally startup, you may re-install now your Internet Explorer.
If in your Internet Explorer you installed yahoo toolbar. Better to disable or remove it. Under the Internet Explorer you will see yahoo toolbar. Then here is the steps to disable yahoo toolbar:
Step 1 – Click the view, -> select toolbar, -> then uncheck the yahoo toolbar. But, I suggest you much better to remove yahoo toolbar.
Step 2 – You can remove it in the Control Panel then Add or Remove Programs category. Same way at the first solution.
When removing some application, you have to restart your computer.
Set the browsing to Enable third-party browser extensions*. How to do it? Follow these steps:
Step 1 – Press the windows key -> select Control panel then select Network and Internet Connections category -> select Internet Options icon.
Step 2 – Select Advanced tab -> then scroll it down and look for the Browsing.
Step 3 – Find the Enable third-party browser extensions* -> then check the check box to enable it.
Step 4 – Click Apply button -> then OK button.
And always keep your Operating System updated. Keeping it up-to-date helps your pc to protect against malicious program or files.
Step 1 – Press Windows key -> select All Programs -> then click Windows Update.
Step 2 – Click on Check for Updates -> then click on Install Updates.
Step 3 – Updated Windows will ensure that your security protection is up-to-date. Windows security protection helps to prevent Trojan viruses and may also help to fix the problems related with Trojan viruses.
Step 4 – Then restart your computer.
Have you already scan your computer using updated antivirus? This is very important to make sure that you can detect if there's virus/spyware in your computer. Then now I recommend you a good scanner, it is HDDScan a freeware programs which help you to detect viruses, Trojans and network worms. And it can fix all the problems related Ram failures, hard disk problems, Registry problems and It supports IDE, SATA, SCSI hard disk drives, Raid arrays, Flash cards and external USB/Firewire hard disks. I recommend this because some of the antivirus can't detect the viruses.
Here is the link of HDDScan:
Download now the HDDScan Installer –> http://hddguru.com/download/software/HDDScan/HDDScan_v31.zip
—Radvele Sam—
I can help you fix the error message on your Internet Explorer. I suggest you to follow these steps:
>>Make sure you install the latest version of Internet Explorer on your computer. The latest version is Internet Explorer 9.
>>Confirm that the computer’s time is set correctly.
>>Try resetting your Internet setting. To reset, type “inetcpl.cpl” on the RUN command and hit enter. Select the “Advanced” tab and click on the “Reset” button.
>>If the issue does not get fixed, try removing any toolbar installed to your browser other than the default toolbar.
This should fix the issue with the Internet Explorer on your computer.
Thanks and regards,
Skarbos Jay
