Hi Guys,
Please have a look at the error message attached below. It is only indication the installation error. If you have any idea for this installation error please help me to solve the issue.
Thanks in advance.
APB Reloaded v1.3.3…
Installation error
OK
Thank you for your question.
Please verify that the installation requirement for this game exists in your computer. This game needs a high configured graphics property. And may be the extended attributes of this application is inconsistent to your system. The error code 255 showing that your system is not support for installing this game.
These kinds of installation errors most of the time occurs due to the incompatibility of software requirements and your system configurations. Check for a read me file within your installation package. Read me file should contain the desired configurations by the system. Check your RAM and VGA capacity and also check whether it supports 32 bit or 64 bit operating systems.
If it supports 64 bit then it also supports 32 bit operating system if it supports 32 bit then it only supports 32 bit operating systems. Checking those items should clarify the issue with your installation process.
