Hi there,
I recently updated IGT slots cleoparta with the igt slots cleopatra ii patch , and there seems to be an endless stream of problems. First it takes ages to start on a highly configured PC and after it launches it immediately freezes. Is there some kind of issues that is plaguing the registry or is there another way to rectify the problem
IGT Slots Cleopatra problems with recent patch
Hi Yvonne,
First of all I’d like to say that all highly configured PC didn’t match the requirements of IGT Slots Cleopatra II. May be it’s the main reason for your problems. Please have a look at the minimum system requirements of IGT Slots then you can easily find out the problem.
Minimum system requirements:
Pentium IV 2.4 GHz processor or higher, OS – Windows XP, Vista, Windows7, RAM – 1GB, 1024X768 16bit color display, 3GB HDD space, 256MB VRAM Direct X9 compliant Video Card.
And be sure that you’ve the proper Administrator privileges to run the program.
I hope this will solve your problem.
Good Day.
