Faye_lee
10 points
Posted on - 10/10/2011
Experts,
I’m trying to install Vault using IIS. I keep on receiving the error that “IIS is not running as the default web browser”.
I tried uninstalling and reinstalling the Vault.
No use.
What all things I tried:
1. I checked and turned off the UAC (User Account control) option.
2. Ran regedit and deleted HKEY_LOCAL_MACHINESOFTWAREAutodeskPLM
3. I had Autodesk Vault Test ASP.Net. I have completely uninstalled it.
Techies, please help me with a different solution.
Error: IIS is not running as the default web server
Thanks in advance,
Faye
lee hung
75 points
Hi Faye,
Follow the following procedure to help solve the problem:
– On your computer, go to the control panel
– While there click classic view then administrative tools
– Then double-click on internet information services
– Check all the services that are under internet information services
Finished that, go to your browser and type localhost and press enter. You should see IIS running now.
____
Lee Hung
Hello faye,
I was searching for a reliable answer for this question, but no answer seems to be a solution. So many people have tried in so many ways. The problem is only the error message is pops up with a string, “IIS is not running as the default web server”. So I searched for its log file. It shows that there are so many services which are not running. So I think if we run it manually it would not show any error message any more. I talked about this with a local expert and he told me the same thing. If after that the IIS shows the same error than we must have to take authorities advice.
Alerter : Stopped
Application Management : Stopped
Autodesk Licensing Service : Stopped
Indexing Service : Stopped
ClipBook : Stopped
Fax Service : Stopped
Flexlm Service 1 : Stopped
Like this above services there are so many other services was stopped. So run those manually from the services.
Thank you,
Riley weaver
