IKEA launches new TV and sound system
IKEA launches new smart TV and sound system that are designed together and its called UPPLEVA.How is this smart TV built together with a sound system and when will its be debut?
IKEA will soon offer UPPLEVA Â which means "to experience something" in Swedish, UPPLEVA is a furniture solution that allows to perfectly integrates your multimedia system in you living room .
In fact it is a line of furniture connected with a fully equipped Full HD LED smart TV (2 USB ports, 4 HDMI ports) equipped with WiFi, FM tuner and manufactured by TCL Multimedia, it includes also a multimedia player with DVD / Blu-Ray, an audio input and a 2.1 audio system with wireless subwoofer, all controlled with one remote.
The furniture in question is made ​​by IKEA furniture design with enough additional storage spaces, and integrates with other furniture in the same series and especially allows to hide all cables.
UPPLEVA has a 5 year warranty and will be available in several screen sizes starting from June.
Thank you
