Illustration contains an incomplete or garbled object description
Hi dear,
I am feeling very strange error in adobe Illustrator. I am using this software from previous 2 year but I don’t see such type of error before it and I don’t know its solution so for solution I post this question at this site. Please provide me good solution.
Adobe Illustrator
Can’t open the illustrator. The illustration contains an incomplete or garbled object description.
            Offending operator: “XW”
            Context:
            u
            U
            1 w
            0 0 Wd
            6 () XW
            1 (Anon 18104) XW
        OK
Answered By 0 points N/A #116130
I think this type of err comes when corrupt any file of Adobe Illustrator.
Don’t worry; it’s not a big problem. First you uninstall Adobe Illustrator using control panel software uninstaller. And you reinstall again Adobe Illustrator. Here you reinstall a purchase copy of Adobe Illustrator.
This err came directly affected by the viruses actually some file are sensitive.
Here you must install a good antivirus and then scan your computer. If you have no antivirus, download any good antivirus (antivirus website). Install it and scan your all computer. After scan all files of Adobe Illustrator. You try to open Adobe Illustrator and start your work easily.  ok
Answered By 590495 points N/A #306777
I think the problem here is that you are opening an Adobe Illustrator file on the wrong version of Adobe Illustrator. Like if the AI file was created using a newer version of Adobe Illustrator and you tried opening it on an older version of Adobe Illustrator, a similar error will appear.
If you have an AI file, make sure to open it on the correct version of the application that was used to create it. On the other hand, if you have an AI file created on a new version of Adobe Illustrator and you need to open it on an older Adobe Illustrator, visit Opening New AI Files in an Older Version for a workaround.
The outcome may not be perfect and some of the details may have been lost.
