sam837
Posted on - 08/09/2011
Hi guys. How are u all m planning to buy an assemble pc from assemble vendors what my dilemma is that to which processor i should opt too. ' intel' or 'AMD'. My i want a pc for professional use as well gaming and dunno for which specifications i should go to. Some says intel. I series is best n some says AMD PHENOM II X2 560 BLACK EDITION,3.3 GHZ please give your suggests m very confuse.
I’m confused to opt between processors. . .
Ok , If you are gaming freak , like high end gamer boy, then you can go for only AMD processors. they are a bit costly in the market but you'll be getting full satisfied and never regret on what you bought. On the other hand you have the option of Intel's I series. They are the I3, I5, I7. I3 is good for professional use and moderate gamers. But if you wan to play your high end games on intel then go for I7, that will be good for gaming purpose as well as for professional use.
Again, it depends on your uses too, whether you'll be more using your computer to games or work. If you give 12 hours of gaming and 6 hours of work. Then go for AMD. AMD's high end graphics handling quality and effects will be better then INTEL. If you use both gaming and work at equal ratio, then go I7.
Choice is your's after all.
