I’m encountering this critical error while running the WOW.exe program
I'm encountering this critical error while running the WOW.exe program.
I hope someone could help me out on this ‘World of War craft error’ that is being encountered.
Wow
This application has encountered a critical error:
ERROR #132 (0x85100084) Fatal Exception
Program: D:ProgrammeWorld of Warcraft 3.3.0 -2Wow.exe
Exception: 0x0000005 (ACCESS_VIOLATION) at 001B:00667667
The instruction at "0x00667667" referenced memory at "0x00000021".
The memory could not be "read".
Press OK to terminate the application.
Answered By 590495 points N/A #89645
World of Warcraft can be installed on a computer that is running on Windows XP 32-bit and 64-bit, Windows Vista 32-bit and 64-bit, or Windows 7 platforms. Your computer must have at least a Pentium 4 1.3 GHz processor, or an AMD Athlon XP 1500+ or higher processor. Your system must have at least 1 GB RAM or more installed on the CPU.
This game requires quite bigger space on the hard drive around 25 GB available disk space. You can also run this game on a Mac OS X 10.5.8, 10.6.8, and 10.7.x operating system.
That is an internal error you got there when launching the game. It is usually encountered during the initialization of the game at startup. Usually, you can fix this type of error by uninstalling and reinstalling the whole package to fix any corrupted files in the installation and to restore its settings back to default.
For complete information about this game Visit Here
