denise
Posted on - 11/01/2011
We are using an Exchange 2003 server where there is a mailbox “Employment.”
The Employment mailbox was added to an individual as a secondary mailbox.
However the individual is unable to forward mail from the secondary mailbox and gets the error message: The following recipients could not be reached; you do not have permission to send to this account.
This only happens with the secondary mailbox, not the primary one. In addition the same Employment mailbox needs to be added to another user using Outlook 2007.
The Employment mailbox was successfully added but when clicked on a message is received that the object cannot be found.
Would appreciate your assistance.
I’m getting trouble with my Mailbox please help.
This is critical problem you are in now, because there were many causes affect by your mailbox. At this moment you must concern mailbox settings and your privacy settings. D.N.S problems, user name or password refused, Unknown situation in virtual alias table.
Those are reasons obtain cannot access e-mail box properly. First you tried to change additional mail box settings (Junk mailbox settings and spam e-mail settings) and try to change the username or password combination for accessing your network. If isn’t solved. Then you can prepare another additional mailbox.
Select the tools tab in the menu bar click account setting in the list. The new Window will be open, in their Microsoft exchange setting. Then type the name of your exchange server also give the name of the new mailbox. Now exchange server window will be open click advance tab and click ok now your new mailbox is ready.
