I’m just wondering how to open .ISO file
Hi Lyle,
Good day Lyle.
There are many ways to open an ISO file . One of the method is you burn your ISO file in a CD. The second option is you download and install WinRaR.
After installing WinRaR you open your .ISO file in the WinRAR . Open WinRAR and drag your .ISO file in it. His procedure will enable you to extract .ISO file as normal zip file. Next solution is you use Daemon Tools. You need to download and install Daemon Tools. After opening Daemon tools right click the daemon tools icon at system tray, select " virtual cd/dvd rom" /"set number of device"/" 1 drive" .
After selection have been done it will process for a few minutes. If the process has been been finished left click daemon tools and select "Device O no media" . A dialog window will pop up, select the ISO file you want to open and then click open. Open 'My Computer" , double click on the new CD ROM drive you'll see all the files within the .ISO file. When you finish just left click on the "system" daemon tools icon and select "unmount all drives".
