Can I use MS Access to make a payroll program?
Yes, you can use MS Access Database easier than Visual Basic 6.0 – you can easily transfer the information. For example you want the info that you typed appear from the list to your textbox or textfield. Hope you understand.
Of course you can use MS Access to create payroll programs, be it simple or a bit complicated.
There are many ways to create a simple payroll program through MS Access so it is really up to you how you want your database to look like.
There are also many sites showing step-by-step procedures on how to create payroll programs such as this one: Microsoft Access – Create Database to Prepare Salary
If you need it immediately and you have no time to design a database of your own, you can just search and download templates that cater to your specific needs.
If the database you have downloaded does not suit your liking, you can even customize it so that it meets your requirements. These downloadable templates can be found virtually everywhere.
