I’m Unable To Open Facebook Over My Home Network
Hi, I’m unable to open Facebook on my PC using D-link Wi-Fi where other websites are working. Please give possible way to open Facebook. Thanks in advance.
Hi, check your browser settings or network settings. Try to default settings in the browser, still face the same problem then check DNS settings. DNS translates a domain name to a respective IP address. Once check your firewall and anti-virus parent controls also whether they blocking FB.
Change network settings such as ipv4 settings, if the DNS is not set then set to 8.8.8.8 (Google DNS) or set open DNS. If above step doesn’t work, try to reset your router.
Resetting router is simple there is a small hole at the back of the router, use a small pin to press it. Make sure you have to know all required fields of router settings, misconfiguration may return problems(This is the last thing you must do) For detailed steps Google for your router DNS setting including model number. (Example D-link 3110)
