IMac Graphics Firmware Update 3.0, software is not supported.
Good day! I was updating my graphics firmware when I got this alert.
How come it is not supported? It's an update right?
Thank you.
Install iMac Graphics Firmware Update 3.0
Alert
This software is not supported on your computer.
Christopher
Best Answer by Bankk benediict
Answered By 30 points N/A #171942
Hello.
The graphic firmware that you are trying to update is not supported with your operating system.
May be the previous version is supported but some updates do not support old operating systems.
Try to contact your service provider for help and support.
May be there might be an issue with the hardware compatibility
Thank you..
Answered By 0 points N/A #171943
This firmware upgrade type The apple company particularly provides with the issues some video cards on iMac methods have been causing in.
Apple has also not precise the techniques for which this upgrade is reliable. So you can verify this by starting the ‘Software Update’ on your iMac and see the spot. If you are able to perspective the spot detailed, then they improve works on your iMac. But if starting the upgrade promotes a concept that it is not a strong on your program, normally it is not suitable for your program.
Do not ignore to backup your program before you apple the upgrade. During the course of set up, the upgrade may trigger your program to reboot a wide range of periods, but that is completely regular, so you need not fear about it.
Answered By 0 points N/A #171944
You can use the list provided in this link to check whether your system is supported for update to the desired firmware or not. Link: https://support.apple.com/en-us/HT201518
To check the details of your computer follow these steps;
·         Choose About this MAC from the APPLE menu.
·         Now click on More info.
·         Open hardware section to analyze the Model Identifier and boot, SMC versions.
