Hi Experts,
I am having a image to be edited.I need step by step instructions on gifs de 64×64.Although I edit it I need to keep the aspect ratio which is 64×64 dimension.I tried microsoft  image editor but need any advance image editing softwares.List me such softwares.Thanks.
Joseph Clark
Image editing gifs de 64×64?
Your requirement to edit the image with an aspect ratio 64X64 dimension is available online at the site https://quickthumbnail.com/. You can insert here your requirement size, format, type etc about the image. You have to upload the image here and the site will automatically provide you the desired dimension.
There are so many kind of image editing software available in the market. You can also collect any one of them. In line with Microsoft Image Editor you may go through this software. Adobe Illustrator is magic software in this regard. You can also download Adobe software as per your requirement. Â Â Â Â Â
I hope you understand it.
I have a suggestion regarding this matter. Adobe photoshop can do many things when it comes to editing. It is more user friendly and reliable because I am using this too when I want to edit something specially when it comes to pictures whether it is gif. , png. or jpeg.
Open your browser and copy the link below in to your address bar. https://filehippo.com/download_adobe-creative-cloud/ download the adobe photoshop CS3 version and install it after.
I hope that this will help you.
