I am using Windows XP, I need to have an image file viewer which will consume less space and just need it as a viewer with zooming options alone, no need to have some other additional editing options. Right now I am using Microsoft Picture Editor for viewing purpose. Please guide me to find an image file viewer, which consumes less space and runs in less memory.
Image file viewer which consumes less space and memory
Hello, Ethan Jessica!
You want to know if there is an image viewer which can run in low memory. I recommend you to use the ACDSee Photo Viewer. With this software, you can view images full screen, one by one, edit images, one-click view, easy to use and many other good features. So when you use this software, you know that it is way better than the others. Hope you get satisfaction from using it. Have a good time. If you have other questions, just visit this site again.
