Image Resolution with adobe after effects seems to be wrong.
Help,
Hello everyone. Can you help me with this one? I’m having just a little problem regarding this image buffer. Is it something like a wrong resolution or wrong size of the image? What do you think are the cause of this and how can I overcome this? I appreciate the help.
After Effects error: could not create 14640 x 14518 image buffer.
( 7 :: 66 )
Answered By 0 points N/A #125576
Problem regarding image buffer is not a big problem. It is a tool in graphics design or Photoshop. It helps you to select a particular area with same format and give you that opportunity to go and edit that particular area. It is a small file in Photoshop library.
If you want to solve this problem you need to install plug-in. You can easily find this plug-in on internet. Installing missing plug-in will solve this problem. You can also visit https://helpx.adobe.com/photoshop/kb/downloadable-plugins-and-content.html for find missing plug-in.
If in your computer you install some similar application program in a same time then uninstall one program, this problem occurs. Similar application share similar file they have and uninstall one program can take that similar file with it. So this error shows. Repair this software or uninstall and reinstall can be helpful.
