echua
40 points
Posted on - 05/29/2012
Hello, I am in a dilemma with my Excel document. I have 3 images on it, and I want to edit them for printing, but I can not see the images. When I print the document, I can see the images, but they do not appear on Excel. My OS is WinXP, office 2007. What might be the reasons behind this problem?
Images do not appear on Excel
Follow the instructions correctly, after follow the procedure you can see the image must appear on Excel.
Answer 1:
Name the cell first. Right click on the cell then choose Define Name, after that Right click on picture. Select Hyperlink then choose Place in this document. Now you can see the name. Set in the Defined Names. Click okay.
Answer 2:
Copy the image. Click the cell where you want to place the image. Right click on cell. Choose paste. Now you can see image on excel sheet.
See the sample image below. Your image is placed like that on excel sheet.
You can easily change the image width and height. You can also rotate the image.
Take printout. Now you can see image on your printout document
