“Images plus” is unsuccessful while selecting the icon capture key
Posted on - 08/06/2012
When I join the microscope in the USB port and then try to select on the icon capture key, the software "images plus" is unsuccessful.
I think, you will be able to give me a solution. Please help.
Thanks a lot.
