CTRL + Q to Enable/Disable GoPhoto.it
I am looking for some error images about SSL. I need it for a project and I need the complete wordings on the error message itself. Those that appears on browsers such as the SSL certificate expired or self-signed, etc. I know this website can provide me what I need. Thanks in advance everyone!
Images of SSL Errors on Browser
I have tried searching for a compilation of SSL Error messages but I couldn't find one, not even a website that provides what you need. But I have posted below what I gathered and I hope that these are the ones that you were looking for.
1. The site's security certificate is not trusted!
2. This is probably not the site you are looking for!
3. An error occurred during a connection to mail.google.com:443. Peer received a valid certificate, but access was denied.
(Error code:ssl_error_access_denied_alert)
4.ActiveSync detected, but access denied. [HTTP 403:Disabled for this user]
5. There is no SSL certificate file for Virtual Service 192.168.1.200:443.
6. Server's certificate is not trusted. Domain Control Validation Error in Certificate has been detected.
7. There is a problem with this website's security certificate.
8. This is probably not the site you are looking for!
9. Safari can't verify the identity of the website "connect.apple.com".
10. Information you exchange with this site cannot be viewed or changed by others. However, there is a problem with the site's security certificate.
Hi
Pay a visit this Techyv post to get more helpful information regarding on this issue.
Check out : Google Chrome SSL error problem
