anonymous
7060 points
Posted on - 11/22/2012
Is there a way to sync imap contacts sync lotus at the same time?
I want to know if there is a way in which I can kill two birds with one stone.
I am very busy and I would like to synchronize my contacts with imap and at the same time with lotus.
Any help?
I have an iPod 3G, will it sync with both?
Imap contacts sync lotus sync at the same time
Yes there is a very go solution out there which is called " Sugar".
With sugar you can Sync Calendar with Outlook, Gmail, Lotus Notes and More!.
Its has got a very nice GUI (graphical user interface) and modern design and it will allow you to easily sync all you data at one place.
You can get sugar from here.
I hope this helped.
Peter franklin
