jamer
200 points
Posted on - 06/12/2011
I have a problem in Microsoft Outlook 2010. Whenever I tried to open it or click on send/receive options, it doesn’t work and shows the error message
"Your IMAP server wants to alert you the following: Can’t read attachment for message 150". When I have to work with Microsoft Outlook 2010 each time this message appears ending with different numbers like 150, 68,252.
Due to this problem I am unable to work on it.
Kindly give me tips to get rid of this problem
june_07
IMAP Server Alert on MS-Outlook 2010
Jamer,
I want to know this first. Is your email server an Imap server or pop server?
jamer
200 points
Well, I'm using AOL and it is an IMAP server.
Hope you can help me with my problem.
pheetong
Errors in Outlook are quiet complicated.
So I suggest you Contact AOL or see if you can access your email from a webmail application and find the email with a bad attachment.
june_07
You better do what Mr. Pheetong said. I also have had a hard time before, when I was using Microsoft Outlook.
You need Customer Service in your case.
jamer
200 points
Thanks!
I just called the Customer Service and they gave me instructions about this.
jamer
200 points
Thanks again.
At least I know that there are also forum's here having the same problem like mine.
Thanks for sharing ideas with me
