Img burn file does not exist
Hi fellows,
I tried to burn a disc using img burn but I failed as it resulted in an error.
The screenshot of the error is as follows:
FILE doesn’t Exist! File name Golden xe – The uel.iso
The message states:
ImgBurn
FILE doesn’t Exist!
It seems as if it is not reading the file. I don’t know what to do next. If anyone has any idea, please do let me know.
Waiting for your advise.
Regards.
Best Answer by Wilson Tan
Answered By 0 points N/A #137940
Hello Jean, so the file that your trying to burn is Golden xe – The uel.iso?
Also I want you to run this program.
Step 1: Go to this website: http://www.burnaware.com/.
Step 2: Download the free version.
Step 3: Install Burnaware.
Step 4: Run Burnaware and try burning your file to your disc now.
Let me know how it works.
Answered By 0 points N/A #197460
Here are few troubleshooting tips to follow:
1. Try to rename the file to a shorter one.
2. Retry the burn at the slowest speed.
3. If you’re burning to a DVD±R, try burning to a CD-R instead.
4. Try the burn with a different brand of CD-R media, some of the cheaper brands are not fully compatible with all CD-writing software.
5. Try the burn from a different PC, if you have access to one
If nothing works, re-install ImgBurn or consider using a different software.
