ImgBurn Setup and tried to run it on my Windows XP
I just recently installed the ImgBurn Setup and tried to run it on my Windows XP Operating System. The error displayed below will help you to find the proper solution so I need your assistance. Can you please do it for me? Any help would be greatly appreciated. Thanks in advance.
ImgBurn 2.1.0.0 Setup
An instance of imgBurn is still running.
You will not be able to install over the top of that version until you close it.
If you are installing to a different folder, you can ‘Ignore’ this warning, sorry to have troubled you!
