There is a strange error message which throws up while using ImgBurn software.
I am trying to burn a .iso image to my DVD with ImgBurn software and it does not let me do the same. I try to insert the layer break it still does not let me go past this error message.
User specified layer break position is such that L0 <L1 – THIS IS NOT ALLOWED!
Image size: 4,101,940
User specified L0 sectors: 1,913,760
Calculated L1 sectors: 2,188,180
Would you like to continue anyway?
Yes No
If I click on Yes, it does something for a few seconds and returns back with the same error message.
Can anyone help me with this error message?
sibabu
5 points
ImgBurn software gives a layer break error message
It would not installed proper way. It performs Windows 7 or Vista or new update version. If you installed in XP let it check out the windows package is properly working for imgburn software.
Image code plays a good level to working properly. Some had missed on your installed software or computer operating system. Don't worry, you can try from renew about this software or re installed then probably it might be works. Be happy!
James14
Your computer might be virus attacked.
Scan your full computer properly.
Uninstall the Image burn software.
Than install it again.
Update the software and see your problem will be solved.
