eachaidh
10 points
Posted on - 06/28/2016
I need some help because of my outlook 2010 out of office not working. My mailbox profile for Outlook is different from my mailbox profile for Windows. I have different information on both. When I logged on to Outlook 2010 using different information, I got the following error message.
Your Out Of Office settings cannot be displayed, because the server is currently unavailable. Try again later.
Can I get some assistance regarding this? It would be greatly appreciated!
Immediate Assistance Requested For Outlook 2010 Out Of Office Not Working!
The problem is that the CAS server uses the Windows credentials and not the Outlook credentials. The first action you will have to take is use the hotfix available at https://support.microsoft.com/en-us/help/2584053/description-of-the-outlook-2010-hotfix-package-x86-outlook-x-none-msp.Then you will have to modify the Registry Editor using the following steps.
• Go to Start.
• Select Run.
• In the Open box, enter regedit.
• Click OK.
• Select
      HKEY_CURRENT_USERSoftwareMicrosoftOffice14.0OutlookSecurity.
• Go to Edit.
• Click New.
• Choose DWORD (32-bit) Value.
• Enter WinhttpAuth.
• Go to Details.
• Right-click WinhttpAuth.
• Choose Modify.
• Enter 1 in the Value data box.
• Click OK.
• Close Registry Editor.
