How to shut down my computer without waiting?
Sometimes I feel to shut down computer immediately but the normal way to shut down computer is not happened immediately.
It takes time.
I am using Windows XP operating system.
Is there any way to shut down computer immediately?
I can pull out the plug or hold the power key but as per as I know it is harmful for computer hardware.
So is there any other way which is not harmful for computer.
Tell me if you know any.
