Immobilize my Windows Sidebar in Vista
My name is Brian and I would like to know, if there is a way for me to remove or immobilize Windows Sidebar.
Well, I know Sidebar is not doing anything on my program or whatever. It does not hinder me from doing something else. However, I do have a little screen as my laptop is just approximately 12 inches. So imagine that I really have a little screen and it is taking much of my desktop.
I cannot seem to see the option to disable it. I would really be glad if someone can direct me with the step by step procedure in doing it in Vista, if it is possible to immobilize it.
Thank you in advance.
and once you have it; then you can right click on it and then select close or exit as it requires. Also you can drag it to some other way you like.
