I just installed the free version of Immunet Antivirus. The problem is, it could not detect and delete all the malware and viruses. It left some Win32 Trojan Viruses. Doesn't the free version have all the features running? I'm on a Windows Vista 64 bit system. Thanks.
Immunet Antivirus does not detect and delete all viruses
Hello Sean,
Trial Version antivirus never helps to remove Malicious/Malware/Virus from the system. Download Malware byte, this software will remove all the virus from your system. I would recommend you to install Microsoft security Essential as security software. This antivirus is light weight software and helps to protect computer from virus.
Thank You.
Hello Sean,
I highly recommend that you should use registered copy anti virus tool to complete your job and also keep your virus database up to date OS that it can protect your system wisely other exiting feature of latest anti virus programs is that you can use your processor to complete its work fast and configure your removable media also easily scanned so  go for it……..
ThanksÂ
