I was thinking of developing web and mobile applications in Microsoft Silverlight by implementing status line Silverlight 3.0 in the user control page. How will I do it?
Thank You!
Implementation of status line Silverlight 3.0 in user control page
It is very easy….. You need to take some step.
1st…
Go to your Control panel & click windows update. Then click change update Setting & keep it as Automatic update (recommended)
2nd…
Go to http://www.microsoft.com/en-us/download/details.aspx?id=4205 Then download the Microsoft Silverlight software & install the software. You need to run after install the software. It will automatically develop.
Once you make a fresh challenge when using the Silverlight Direction-finding App web template, your web template generates some sort of XAML data file which has permanent URINARY INCONTINENCE elements as well as a figure intended for navigating articles. The idea exists in some sort of person management known as Primary Site.
You may create additional URINARY INCONTINENCE elements to LayoutRoot previous one as well as immediately after Articles Figure. The original source house is scheduled to /Views/Home. Xaml meaning that by default your site displayed within the figure will be the site located in /Views/Home. Xaml.
Contain fresh web pages on your program when using the Put Brand-new Merchandise discussion pack as well as selecting Silverlight Site. This Silverlight Direction-finding App web template inside Graphic Facility makes some sort of folder known as Vistas that contain web pages.
Contain web pages to the folder, as well as you can add web pages anywhere in your application that is certainly most suitable.
I hope it helps you.
