Implementing oracle report builder open office integration for report generation
What procedures are paramount in oracle report builder open office integration and implementation to ensure a back and forth communication between the two applications for efficient and on-request report generation?
Best Answer by Shifflett Laurel
Answered By 0 points N/A #194902
Hello Beatricegvavra,
Oracle Report Builder is the most compatible ,user friendly software which has some unique components like query builder, pluggable data sources,live editor ,dynamic SQL etc.
To implement of this program :
  • Firstly you have to download and install latest version of java from the following link.
  • http://java.com/en/download/index.jsp
  • Then download  the latest version of Oracle Fusion Middleware [1g Release 1 (11.1.1.4.0)].
  • Create the database Schemas
  • Install an application server ,Oracle Web Logic server is recommended.
  • Install Oracle Fusion Middleware
  • Configure your product and create the webLogic Domains
  • Enjoy the charisma of this program.
Wishing the best
Shifflett Laurel
Answered By 0 points N/A #140555
First, you have to download and install the latest version of Java, then you have to download  the latest version of Oracle Fusion Middleware, then create the database Schemas, after it install an application server, then install Oracle Fusion Middleware. Finally,  configure your product and create the webLogic Domains.
