Import Contacts from BlackBerry to Samsung SII
Hi.
I just want to know how I can import my contacts from my old Blackberry contacts to my new Samsung Galaxy SII?
Hi.
There is software used to sync your phone you may download the program at bitpim.org download and install the program. After installing the program have a connection between your phone and computer and then open the bitpim program and then edit > detect phone and then on bitpim data > Get phone data now you will see the data that you want to get.
Select the phonebook and then File > export > vcards and save them where you prefer to save them and then after saving connect the other phone and then open the program and then import the data to your Samsung phone
If you want to copy your BlackBerry mobile contacts to an android phone such as Samsung Galaxy S II don't be tensed it is possible.Â
Firstly go the address http://www.google.com/sync/index.html from your Blackberry phone. It will detect that you are using a BlackBerry phone & give you a link to download Google Sync App.
Download Google Sync App & Install it. It will be shown on your BlackBerry App list.
Now open the Google Sync App. on your blackberry. Then Log in to your Google Account. There you can see a "SYNC NOW" button at the bottom of the welcome screen.
Once the Synchronization is done on your Samsung Galaxy S II handset click the Menu button and go to settings>data synchronization make sure the contacts setting is checked.
Then hit the menu button again and click ""SYNC NOW".
Hope that you will get your result.
Regards
Iirean Hatch
Thanks Iirean Hatch for your awesome response!
I followed the steps you gave and I was able to transfer my contacts!
Thanks a lot.
Many thanks TechyV!
