Hello expert,
My friend is using yahoo messenger on his notebook. But he did not know how to import history into yahoo messenger from internet explorer. If possible please can you suggest me a way to explain my friend to continue this process?
Import history into yahoo messenger from internet explorer
Hello Toby Maloneer,
If you want to save the mailing history or a back up then you can do that in a very easy way all you need is to follow the steps that are given below. You just need to save your messages that are in yahoo.
Once you save that you can easily access them from your C drive. You have to go to C drive after that Program files and there is a folder for yahoo and you can get all your save data from there.
Hello Toby,
You can be able to get yahoo messenger history by enabling Archives. This can be achieved by going to yahoo messenger click on preferences then message archive. Click to save all messages and then finally ok and you are done. You can also get a free and secure backup program called DEXPER where you can backup all your contacts, messages and links. Here is the link to Dexper: http://ww4.dexrex.com
