Import messages error occurred with MAPI client
I received the following error message when I tried to import my email messages from Outlook 2007 to Windows Mail. I reinstalled the program to resolve this error but could not find any result. Have any idea to resolve this error message? Really, need your suggestion.
Error Message: Messages cannot be imported from the MAPI client. An error has occurred.
Answered By 5 points N/A #185542
Hi Taylor,
Here are some possible reasons why you're having that error:
  • You're trying to import your message to your Outlook 2007 even if you have already removed it from your computer.
  • You make the Outlook 2007 as your default Messaging Application Programming Interfaces or MAPI client.
Here are the ways to solve your problem:
  • If you removed Outlook 2007 on your computer you need to install it again.
  • Change the MAPI default client. Follow the instructions below to change the MAPI default:
                Step 1: Launch your Outlook 2007.
                Step 2: Go to Tools > Options
                Step 3: Go to Connection > Change and the Internet Properties will appear.
                Step 4: Go to Programs then select other email application that you want to use except Outlook 2007 in the list. Hit Apply then OK
                Step 5: Hit OK the close the Option window.
                Step 6: Close the Outlook then reboot your computer.
You can now use it. I hope this can help you.
